586,062 active members*
4,756 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > laser with MPC 6525 - laser blocks after pressing the START button
    Aug 2013
    Hello,
    This is my first post here and I'm looking for a solution for a WEIKI laser bought with a MPC6525 controller.
    I have recently bought the laser 600 x 400 mm and I'm looking for a solution with a problem that is not yet solved and because of this the laser is not usable.
    I was able to work with the laser for some weeks so I think I'm a little bit familiar with the software Lasercut 5.3.
    The laser is connected through a USB interface with a pc. I can control every movement and jogging of the laser from software and on the laser panel, but when after downloading the file, I press the "Start" button in the software or on the laser itself, everything blocks. Nothing is possible anymore and the laser blocks completely. None of the buttons on the panel are working. The only thing I can do is restart the laser machine and everything is back to normal, by that I mean that I can jog, fire the laser and so on but cutting or engraving is not possible. Every time I press the start button to start a job the laser blocks.
    If you have a suggestion or if you know what is wrong, I would appreciate telling me the solution very much.
    Kind regards, Wendy
    Aug 2013
    Did you get any help from Weiki and have you solved the problem? I hear that there is a firmware patch for this.
    Feb 2012
    387
    Wendy,
    ask your sales person to get a file to solve this problem,I am sure we can help
    Best Regards
    Quote Originally Posted by WendyL View Post
    Hello,
    Kind regards, Wendy
    Lucy Lee G.WEIKE LASER
    [email protected]
    Aug 2013
    Hello Sandgroper
    After some mails and a Skype session the technician decided that the controller was broken. I had to sent it back on their DHL account and after 5 days I received a new Leetro controller.
    Everything is working again.
    Regards, Wendy
  1. Laser won't start
    By adrianhdezch in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2014, 01:12 AM
  2. Method of finding problem if no laser & PSU has no test button
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-28-2013, 11:42 PM
  3. Help with K40 Moshi Board - Laser On with Test Button but off when running
    By techrat in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-17-2013, 02:03 AM
  4. Chinese laser: when I press the left button, head goes right...
    By Mchawkeye in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2012, 08:33 AM
