586,060 active members*
4,238 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Communicating CAM to Fadal
Results 1 to 7 of 7
    Aug 2013
    Angry Communicating CAM to Fadal
    I have master cam 9.1 and I have a 1999 Fadal VMC and while reorganizing my shop, the cable used to communicate the two was lost. I bought an adapter to go from parallel on the back of my machine to serial and then ran a serial cable to the computer with master cam on it. now I cannot send files to the Fadal anymore. As far as I can see the baud rate and all other settings are the same, but it just doesn't send any files. Master cam said they will not support me but the only suggestion they could give was to make sure my computer recognized the adapter.
    Dec 2008
    717
    Ahhh. Fun with RS232...
    First, Why did you need an adapter? Was there a reason you didn't just get another cable like the one that was lost?
    Tim
    Dec 2008
    717
    I'm going to second what mastercam said.
    Tim
    Apr 2003
    3578
    Fadal lines are not parallel on the cable so Fadal made this adapter for twisting the lines in the right order.
    I would call Shop Floor Automations | DNC, CNC, Predator Software, Wireless, OEEShop Floor Automations | DNC Software Communications & Machine Monitoring and order a cable with one end connector for Fadal and ether the 32 or 15 pin male or femail you need on the other end and be done.
    I carry one of this cable system in my bag when going into shops so I can connect with and controller I want by just changing the ends for the controller.
    Cadcam
    Dec 2008
    717
    Quote Originally Posted by cadcam View Post
    Oh man that is right...I forgot about that. One more negative for fadal...no wonder they went bye bye...
    Tim
    It's been a while since I've played with a Fadal, but the last one I had was a 2000 model. I used a cable I got at Radio Shack that was 25 pin on one end and 9 pin on the other end with a null modem attached on the end of that. I still have that cable. I don't remember if I used Mastercam for communications with it ever, but I know I did use Fadal Assist. Which I still have a copy of.
    May 2005
    14
    This is the pinout for communication cable I have for the Fadal.
    9 PIN
    #2 RED
    #3 WHITE
    #5 GREEN
    #7 & #8 JUMPER
    #1 & #4 & #6 JUMPER
    29 PIN
    #2 RED
    #3 WHITE
    #7 GREEN
    #4 & #5 JUMP
    #6 & #8 & #20 JUMP
  1. Replies: 5
    Last Post: 08-08-2023, 07:31 PM
  2. Heidenhain TNC 426 communicating with XP
    By HARDTOOL in forum Uncategorised MetalWorking Machines
    Last Post: 11-22-2009, 01:34 PM
  3. boss 6 communicating
    By timprebleco in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2008, 06:48 PM
  4. Communicating with the machine
    By GM81 in forum Mastercam
    Last Post: 12-09-2008, 03:20 AM
  5. need help communicating to Fanuc Omc controller
    By maxvic in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-17-2005, 03:03 AM
