Hi All!
I'm working on a new machine build using kflop as the primary controller to control motion on 4 axes. Just to give you an idea of the end result: the base track is horizontally aligned circular with a vertically aligned hemispherical arch spanning the base track; the vertical arch rides on carts that move along the base track (in equal and opposite directions). Along the arch, another cart rides up and down and preforms work. More about that later I'm sure...
So I've managed to acquire a servo/amp combo with very poor documentation to say the least...
Here's my setup:
Attachment 195264
The amplifier shipped with the 2 cables needed to connect to the servo, but what I seem to be missing is some sort of power supply cable for the amplifier. Also, the amplifier appears to be an RS232 connection so will I need to get a kanalog board for connectivity?
Thanks for your time!
