586,106 active members*
3,134 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Timing belt driven router - updated pictures
Results 1 to 20 of 20
    15
    Hi, Just uploaded a few more photos of the router table we built for
    Plastics Plus. Shows an example of how timing belts can be used for X
    and Y. In the current configuration, maximum rapid travel speed is
    480ipm. Plenty of torque as well.
    http://www.axxustech.com/Axxus4x8/axxus_4x8.htm
    779
    Nice work Dean!
    I posted a picture of this style of movement along time ago. I'm glad to see it in operation.
    How does a laser level work to help you keep things flat and true while welding the frame?
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    103
    Dean, interesting design.
    What kind of repeatable accuracy are you getting with the belt drive?
    Did you source the belt and V groove components in Canada?
    Steve
    www.tac-pro.com
    15
    Jeff: I made the two sides of the frame first. They are the two pieces that look like bridge trusses. Then I had to insure they were perfectly aligned with each other before welding them together with the three cross members. A rotating laser in the center of the table gave me a reference line to make sure the two trusses were not skewed. I suppose I could have used a regular level, but the laser sure made it easy.
    Steve: Resolution is .0005". That was plenty for the plastic pieces that the machine is used for. Linear rails and vee bearing were shipped direct from Bishop Weiscarver. The 10 ft shipping box only weighed 40 pounds, but because of the length, it had to come by truck freight. It cost a small fortune to get it here.
    Jun 2003
    2103
    Dean how wide is the belt?
    turmite
    No greater love can a man have than this, that he give his life for a friend.
    15
    25mm
    Sep 2003
    44
    Any stretch?
    What kind of load will the belts take? Could you cut 1/4" AL with the machine holding that half thousandth?
    What is the gear down ratio from servo to belt pinion?
    Tim
    TT
    15
    Hi Tim,
    The belt is a Gates long length #LL5MR25 Powergrip GT with fiberglass tensile member. The rated allowable working tension (Ta) is 253lbs, but they dont give a spec on ultimate tensile strength. Cant comment on cutting 1/4" AL because we've never tried it. The Belts have been under significant tension for over 3 months now without any sign of stretching or loss of calibration.
    The reduction is 9:1 from the motor to the "pinion". The pinion is gates part #P18-5MGT-25 PB. The pitch diameter is 1.128" and it has 18 teeth.
    Oct 2003
    81
    Hi Dean,
    Nice design! I have been working on a similar design with the belt above the table rather than below, which allows the "pinion" pulleys to both be mounted on a common shaft running through the gantry.
    How did you manage to get 9:1 reduction? It looks like 18 tooth to 54 tooth would work, but I can't find any 54 tooth pulleys.
    Steve Aldridge
    15
    Hi Steve, yes I used a common shaft through the gantry as well, but it is connected directly to the motor. Then there is a 9:1 reduction on each side of the gantry from the common shaft to the pinions so the pinions are turning 9 times slower than the motor. The pinions themselves are not involved in the reduction. They only provide the traction for linear motion at a rate of 3.542 inches per revolution.
    Sep 2003
    1469
    Dean,
    Good looking machine.
    I’m designing a stepper controlled machine about 28” X 36”. I really like your belt drive system, do you think it would work on a stepper driven machine that would be cutting aluminum occasionally?
    What would the negative aspects of a belt vs a lead screw machine?
    Hager
    May 2003
    37
    Hi Dean
    Great Design
    Do you sell any of your plans or "Bill of materials" or info?
    I want to use the belt concept and the Vee bearings in my design.
    Bill
    Jun 2003
    453
    I must say I like the idea of belt drives. Is anyone else here using a system like this? After using it for a while is it still your prefered method over ball screws? Any other comments?
    Splint
    Jul 2003
    Hi
    I found this link with timing belts drive mashines
    http://cnc25.free.fr/machinescnc25.htm
    Nov 2003
    244
    I aquired some 3/4" (19mm) wide belts with 20 steel cord reinforcing that I plan to incorporate in my next design. pretty much along the line of Deans machine. Nice job.
    ...He who makes no mistakes makes nothing! ...
    Tom
    Apr 2004
    678
    DeanC500: Very nice! What's your experience with the gearing? It seems to me that you will get appx 10mm/rev and with that motor it should translate to around 65Kg! pull at the Y-axis. Did you experiment with this to optimize acceleration and speed?
    cutfinger Guest
    I am using belt drive on the long axis of a machine I built and use commercially. I chose to use a stepper motor with a driver set to 5,000 steps/rev which negates the need for building reduction gearing and the backlash it can introduce even if carefully made.
    I am getting blinding fast G00's and smooth G01's. The resolution is .0008 which is fine enough for what I am doing but can easily be reduced with a smaller timing pully on the stepper shaft.
    Photo quality printers, I believe, all work with steppers and belts and there is nothing more demanding than a high quality colour print.
    I am an unashamed stepper man and have found that if you use them within their range they do not make mistakes. Microstepping is the key.
    cutfinger Guest
    15
    Hello, the machine was very easy to setup and calibrate. It has a maximum speed of 430ipm on the x and y. Small repeatable movements of .0002". There is no backlash. The system has performed flawlessly since it was installed nearly a year ago. Belts have stayed taught and I haven't had to tension them yet. I would definitely use belts again over lead screws. I have also seen good results with rack and pinion. The Trumpf CNC lasers I work on are worth over a million dollars each and they use rack and pinion. The machines have to be meticulously leveled and also be very rigid, then the pinions adjusted to get rid of any backlash. Rapids on those machines are 8000ipm on x or y and 12000ipm diagonally. Z axes are were generally gear reduction driving a belt, but recently they have gone to linear motors on Y and Z (Y is across the gantry and X is the long axis). I am planning to build a plasma table this summer designed after the Trumpf machines. I am aiming for rapids over 2000ipm (why? just cause I can) so I will have to use belts or rack, and huge high torque motors with little gearing.
    cutfinger Guest
    Why is everyone so taken up with rapid moves, how fast does one really need to go?
    Just using an unfashionable stepper motor with a timing belt driven directly off the shaft my cutter spindle has returned the 5ft home long before it has stopped rotating. I have a mechanical brake on the spindle so I can increase output!
    I am cutting at 100 inches/min which is what works for my application - I could go much faster.
    It is all about applications and personal preferences to what works but it does seem that steppers have got a bad wrap because they cannot cut the air as fast as servos'
  1. Timing belt length calculator.
    By dmgdesigns in forum DIY CNC Router Table Machines
    Last Post: 01-06-2009, 01:54 AM
  2. timing belt reduction
    By drwc in forum Benchtop Machines
    Last Post: 05-23-2005, 09:31 PM
  3. timing belt question
    By Aegeon in forum DIY CNC Router Table Machines
    Last Post: 05-18-2005, 03:50 PM
  4. Converting a mini from geared to belt driven
    By cncadmin in forum Benchtop Machines
    Last Post: 11-04-2004, 05:15 PM
  5. Any recommended Timing belt and pulley?
    By starCNC in forum Uncategorised MetalWorking Machines
    Last Post: 08-01-2004, 05:29 AM
