586,112 active members*
3,112 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Help with NPN proximity sensor wiring in parallel
Results 1 to 11 of 11
    Jan 2012
    5
    Ok i have my sensors mounted and they work if i only have 1 sensor. however as soon as i try to run them in parallel i can not get them to trip unless they are both tripped. Helllpppp I am abut to pull out my hair.
    These are the sensors i am working with I am using 12 v power supply to power them Amazon.com: Amico DC 6-36V 300mA NPN NC 8mm Tubular Inductive Proximity Sensor Approach Switch LJ18A3-8-Z/AX: Home Improvement
    I am using this as the BOB
    http://www.kelinginc.net/KL-DB25.pdf
    Aug 2004
    2849
    How do you have the switches wired? Do you have the instruction with the switch or a data sheet?
    Feb 2007
    4553
    Bean_086,
    If you are only using one input for multiple NC proximity sensor's they need to be connected in series.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2012
    5
    I dont have any specs on them just what amazon has on there site. I have the + on both sensors to my 12Vdc+. I have the - wire on both sensors connected to my 12v- dc power supply, and i have both of the switched legs conected together to a resistor that is then connected to my breakout board that is associated with that axis 11:x, 12:y if i have just one sensor connected it reads correctly in mach 3 and if i have both connected and tripped it reads correctly in mach 3.
    Jan 2012
    5
    how would you wire in series
    24221
    They are N.C. so if you have them paralleled one will still be closed.
    They need to be open collector N.O. to run in parallel.
    Al.
    Albert E.
    Jun 2011
    72
    NPN sensors have the load between the positive and the switch wire, meaning that the sensor is switching the negative part of the load circuit to ground.
    Not sure how you have it wired in your CNC but in mine but I connect the switched wire directly to the input. When the switch has something in its proximity range it pulls the switch wire to ground (and hence the input to ground).
    I have never looked to see what is it doing when it is not activated (floating voltage or high voltage), but I would install the 2 switches in parallel with no resistor. If either switch is triggered, then this will pull the input low.
    Of course for this to work you would need a breakout board that has pull up resistors, so the input is held high unless a switch is triggered to pull it hard to ground.
    Attachment 195458
    Cheers
    Bushwakka
    Aug 2004
    2849
    Hopefully you've learned not to buy stuff with out any specifications. You can't use a single resistor, each switch must have it's own resistor that way they can trip individually.
    Bushwakka...I believe what you have are the NPN NO (normally open) type of proximity switches.
    Feb 2007
    4553
    Post
    Bean,
    See attached diagram for wiring switches to multiple inputs.
    You must use a resistor for each switch.
    Jeff...
    Jun 2011
    72
    Bean,
    The switches you have are unable to be connected in parallel to both trigger the same input with OR logic. Because they both pull the switch wire to ground, they can't be wired in series. You will require NPN Normally Open (NO) switches in parallel for active low ( pulling input to ground) or PNP Normally Closed (NC) in parallel for active high (pulling input to supply voltage).
    Viper, you are correct with regards to NO switch.
    Cheers
    Bushwakka
    Feb 2007
    4553
    Post
    Bean,
    Here is a example of multiple PNP proximity switches connected to one input in series.
    The switches are PNP in this example.
    Jeff...
  1. Proximity sensor or home/limits?
    By kevincnc in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 05:43 PM
  2. Limit / Proximity Sensor KMB1
    By Bob La Londe in forum HURCO
    Last Post: 09-14-2012, 04:29 AM
  3. BB does not read +5 from proximity sensor
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 03-25-2012, 02:01 PM
  4. proximity sensor issue
    By strohkirchw in forum Benchtop Machines
    Last Post: 05-27-2011, 10:14 PM
  5. J325 Z axis proximity sensor ???
    By lavrgs in forum Tree
    Last Post: 08-31-2009, 04:36 PM
