Just a though of a inexperienced hobby CNC router builder.
If you use one bronze nut on the thread axis, the bronze nut will start wearing out.
When the space becomes 0.2 mm you might want to replace the bronze nut.
Cost money :-)
Here it might be better and cheaper to use two bronze nuts instead of one.
http://home.wanadoo.nl/vroemm/cnc/two-bronze-nuts/
Turn the nuts to make them press together lightly.
When it starts wearing out, you can turn the nuts again, with this removing the space created by wearing out.
When you want to do a extra accurate job with your cnc router, you can adjust the nut before you begin.
No need to wonder if you are going to spend the money of buying a new nut, just for this one extra accurate job.
You can keep repeating this until the thread in one of the nuts is completely gone.
At first it is more expensive because you have to buy 2 nuts to start with.
At the long term it becomes cheaper because you can use the nuts much longer.
In the picture above you see two nuts which a worn out a lot.
In this way the nuts are still usable.
