586,106 active members*
2,955 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Speeds, feeds, and d.o.c. in aluminum question.
    Jun 2012
    8
    I'm using a carbide, 3-flute, 60 degree helix end mill. 5/32 cutting diameter w/ a 3/16" shank and 9/16 length of cut. I need to mill 1/2" thick aluminum. what would you reccomend for depth of cut, speed, and feed. It's a Fadal VMC40 with an 8000 rpm spindle. Thanks.
    Apr 2012
    40
    I'm assuming full slot cut width, with not more than .75 stickout, 8000 rpm, .03 - .05 doc, 20 - 30 ipm. Try the low end first and work your way up until you feel comfortable that your not pushing too hard. If the 3 flute starts to be trouble try dropping down to 2 flute, in aluminum you may need the extra chip clearance.
    Sep 2012
    255
    I would be starting at 8000 rpm 54.0 IPM.
    At 0.025" deep for slotting.
    If endmill handles that well you could bump up the depth a bit.
    http://zero-divide.net
    FSWizard:Advanced Feeds and Speeds Calculator
  1. MDX Feeds and speeds and aluminum oh my!?
    By xesxes in forum Benchtop Machines
    Last Post: 11-15-2013, 03:04 AM
  2. Aluminum Speeds&Feeds
    By dlange in forum Uncategorised MetalWorking Machines
    Last Post: 05-22-2013, 09:30 PM
  3. CNC'ed X3 speeds and feeds question
    By Geekus in forum Benchtop Machines
    Last Post: 03-28-2012, 04:38 PM
  4. speeds and feeds question
    By NORM KENNEDY in forum UG NX
    Last Post: 05-31-2011, 02:01 PM
  5. Feeds & speeds Question
    By Janos in forum Haas Mills
    Last Post: 11-28-2007, 01:46 AM
