Yeah that was what one of my main concerns until I got the mill head in my hands, then I figured it out with some online help from these guys. The pulley I bored out (actually over bored by a couple of hairs)to fit on the spindle which is about 1 1/8 " diam. On top of the spindle head originally there sat a sleeve with a slot (this for the spindle lock so when your changing collets it won't move) and a spanner nut which held it down, I removed these and just set the pulley on top, it has a set screw to hold it down, right behind the spindle on top is a smaller shaft that that use to hold a plastic gear(this is the original drive on the mini mill), anyway on this shaft is a small groove which is deep enough that a small rod can be pressed against it and it will be my spindle lock, also on the head there was a lever for changing the hi / lo gear (mini mill), this also is not needed and was removed. I probably spent 3 weeks trying to picture the mill head and how to do the pulley setup and loosen the drawbar(a threaded 7/16 20 which I don,t have yet) but once the mill was in my hands I was like oh, this part will be easy. Tomorrow I,ll take a couple of pics with the pulley off and how it goes on....
