586,042 active members*
3,830 visitors online*
    Aug 2013
    17
    DIY Floating head
    I am looking at making my own floating head. I have searched the net and can not come up with anything. Also what post would I use in sheet cam and set everything up once I get it made
    Jun 2004
    6618
    Okay. If you are looking for a design for a floating head, there are many ways to do the same thing.
    Here is a link to your other thread, so guys can see your Z axis now.
    http://www.cnczone.com/forums/genera...ch_height.html
    Your floating head would be mounted where your torch mount is now. On that vertical plate. Mine only uses gravity and the weight of the torch head and mount. I have seen them made spring loaded. They can be very simple or quite complex in design.
    I have a split floating head design on mine. I use a die grinder to do engraving and it floats too, but doesn't use a switch. Again gravity only on that slide.
    You will need a small slide of some sort. The more accurate, the better up to a point. It can get some crusty build up on it and stop motion if not cleaned regularly.
    I spray a liberal amount of WD40 on mine before and after use to keep it flushed clean.
    I just used some linear ways that I got off EBAY. I had them on hand for awhile.
    Most use some small or at least short ways. Mine have 6 inches of travel and that is a lot more than needed.
    Maybe someone will post some plans. I don't recall seeing much in the way of plans. Basically just napkin drawings is all I saw.
    Lee
    Jun 2009
    226
    Look at my build here on the zone, A Different Machine - Downdraft/water table. I have two designs around post 30 - 35. The final design is just an aluminum block and 4 sealed bearings. Very simple and it works great. Also look at post 63 for a limit switch that has near perfect repeatability which you need for this function. A regular microswitch has too much variation.
    Good luck,
    Willy
  1. Floating Z Head
    By tulsaturbo in forum Mach Plasma / Laser
    Last Post: 03-18-2021, 11:55 PM
  2. floating head
    By lowfronty in forum SheetCam
    Last Post: 07-01-2013, 02:18 AM
  3. floating head
    By lowfronty in forum Mach Plasma / Laser
    Last Post: 05-14-2013, 02:36 AM
  4. floating z head
    By BuiltByBrooks in forum Waterjet General Topics
    Last Post: 11-12-2010, 01:15 AM
  5. Floating Head Improvements?
    By Normsthename in forum Waterjet General Topics
    Last Post: 05-27-2010, 01:12 AM
