I am new to using bamboo plywood-- see attached images,
Attachment 195880
Attachment 195882
does anyone with knowledge about bamboo plywood know what the cause may be?,and how to prevent it?,
bamboo goes through a unique process to become plywood,gluing with the grain with the stalks laid out side by side,
I have heard of the possibility of there being air pockets which I thought was the problem at first
but then unlike with the rest of the cut area,the laser did not go through to the reverse over the charred areas!,
so now I'm thinking the charred areas are where the wood is harder for some reason and as I had the power up high at
low speed this result occurred,
thanks in advance,
Graham,
