586,058 active members*
4,600 visitors online*
    Oct 2005
    19
    Optomizing Gcode
    After I draw on Qcad then take over to Kcam to convert it to Gcode I end up with a lot of useless operations. Like jumping all over the medium I'm cutting ( not in order), not to mention going up and down over one point several times. There also seems to be random cuts that are unintentionally made. I have tried to use a Gcode optimizer, to no avail. I tried to use PCB Gcode to clean it up but it requires all X,Y and Z statements to be on separate line numbers. Any help would be greatly appreciated.
    Thanks Gary
    Jun 2013
    7
    Gary,
    I'm new to KCam myself, but have found that KCam will set up a cut path that follows the sequence that you drew the segments in. I redraw objects in the order I want them cut to optimize the path. There may be a better way, but I am too new to KCam. and have not found it. I use TurboCad 18 pro.
    Oftentimes I will re-arrange the G-code by hand after it is generated. I also use the find and replace(the binoculars) to change the cut depths.
    I hope that helps,
    Randy
  1. Optomizing Vacuum Table hold down pressure
    By gerry2112 in forum Commercial CNC Wood Routers
    Last Post: 10-06-2009, 11:00 PM
  2. DXF to Gcode
    By Karl_T in forum NCPlot G-Code editor / backplotter
    Last Post: 06-20-2008, 01:09 AM
  3. stl to gcode
    By 9xnet in forum Uncategorised CAM Discussion
    Last Post: 05-28-2007, 10:07 PM
  4. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
  5. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
