Hello,
I have encountered a very bizzare problem with one of our lathes, hopefully someone has experienced this before and has an idea of what I could check.
The machine is an SL-20 new april 2007.
Today while running a program that has been running for 4 days with no problems the spindle slowed down and stopped in the middle of a finishing pass and the control is reading 200% on the spindle load.
I restarted the machine and started it at 2000rpm in MDI. It starts, speeds up like normal then over 10 seconds or so it slows down to zero rpm and again is reading 200% spindle load.
The belts look good, and the sindle can be turned by hand freely once it has come to a stop. No obstructions.
I also have discovered that this problem does not occur below 1300rpm. 1299 runs fine, but when it hits 1300 the load jumps to 200% and it slows down to zero rpm over a span of about 10 seconds.
Any ideas?
