586,121 active members*
3,330 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Trying to get Viper tune to work
    Aug 2008
    303
    I just sent one of my servo drives in for repair, and was told by Larry that there was a Viper tune available.
    Here's my problem;
    I tried to get one of my viper drivers connected to my newest laptop, but it does not have a 232 plug, so I'm trying to connect it using a USB to RS 232 adapter. Not having any luck even with having the 9600 Baud rate checked.
    I do have a real old laptop that I used to originally to program my servo drives, but I have no way of getting the "Viper Tune" software on it. I can't connect to the internet with it because it only has a dial-up modem. I can't use a USB stick in it because it wont recognize USB 2.0. I can't use a floppy because I have no other computer to be able to transfer the program onto. I can't burn a DVD because my old laptop only has a CD reader.
    My only option is to use my newer laptop, but I can't get it to communicate with the Viper drive. They are version 2.6 if I recall and about 5 years old. Any idea on what else I can try??
    The one that dies with the most tools, WINS !!
    www.dantechfabricating.com
    Aug 2008
    303
    I don't know how I did it, but I got my newer laptop to communicate with my Viper drive. I was able to enter "v" and got a reply that it's running version 2.5. I didn't spend too much time with it, but I do have one question. Is it even worth running this program with the older versions?? The main item about this program is the exerciser, but it won't work on older versions.
  1. Viper Tune is ready !!! Finally
    By Larken in forum Viper Servo drives
    Last Post: 01-18-2021, 07:55 PM
  2. Viper Tune problems.
    By CATCH22 in forum Viper Servo drives
    Last Post: 05-03-2013, 12:41 AM
  3. Best Breakout board to work with Viper 200's and Mach3?
    Last Post: 01-10-2012, 10:14 AM
  4. Can't Tune the Motors??
    By CurtisBarclay in forum Mach Mill
    Last Post: 04-13-2009, 12:48 AM
  5. X2 Tune up?
    By Micro Rotors in forum Benchtop Machines
    Last Post: 02-16-2007, 12:00 PM
