xjdubber,
There are a few of us here that handle tech support. We each deal with several thousand customers from around the world.
Our database does not show xjdubber. We even checked for mis-spellings of it. The notes show over 50 Strippits.
Possibly others maybe able to help with your remaining multitool issue. We realize that people post here to get others help, so we try not to intervene unless it's warranted. While you may get your answer for multitool here you have other more concerning issues that you may need our help with and while you may have already solved them, there maybe more difficult questions that come later.
We hear you, when you say the remaining pressing issue at the moment is multitool. We can confirm that multitool on a Strippit Punch does work. The greatest number of tools being 330 in 3 separate outer, middle and inter rings on a Turret Punch Press up to 8 axis on multiple stations. Multitool is an advanced topic and our definition maybe different that yours. We are willing and able to provide whatever is required which maybe customize for you.
You may say, you can't get Multitool to work but please don't say Multitool doesn't work if you want our help.
Tech Support
CamSoft Corp.
[email protected]
PH 951-674-8100
Fax 951-674-3110
PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
