586,058 active members*
4,716 visitors online*
    Aug 2013
    13
    Lightbulb Meldas 64 Manteinance Mode
    Hello, everyone.
    I'm trying to figure out how to change the input port from a Mitsubishi Meldas 64. Reading the M60's handbook, I found out there are 2 valid values for the parameter (#9001):
    - Set 1 --> to use Channel 1
    - Set 2 --> to use Channel 2
    Currently, I'm not allowed by the CNC to put "1" as the port number. It shows me "E02 - Data Over" (meaning I'm out of range).
    As I read, Channel 1 is used for manteinance functions, so I figured.. If I can change the operation mode to "Manteinance", perhaps I'd be able to change the port and establish the communication with a PC.
    What is specifically the function of "the maintenance function data input/output #(99)" ?
    Attachment 196096
    It isn't explained in the manuals. What values do I have to set there?
    I'd appreciate any feedback.
    Regards
    Martín
    Aug 2013
    13
    Another alternative I've been reading about is placing the "NCSYS" switch in any position from 2 to 7. That would apparently make the system enter maintenance mode.
    Has anyone done anything similar? Thanks!
    May 2019
    7
    Re: Meldas 64 Manteinance Mode
    Hi
    I have a similar problem and it is not changing the parameter 1037 to 7, this change is done when sending information, but after turning the control on and off, I change to 1 and when changing it manually, the alarm has E02 data over, Thanks if anyone can help me, my Machine is Mitsubishi Mori seiki cl200
    Jul 2007
    26
    Quote Originally Posted by Milad127 View Post
    Hi
    You turn rotary switch 0 =1 so change parameter.
    https://www.scribd.com/document/1338...4-RS-232-Setup
    Aug 2014
    161
    the port is changed on the I/O Parameters page under the tools hard key, menu soft key, I/O PARA
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. 1996 LEADWELL VMC25 MELDAS 300 TAPE MODE
    By josemanuelcorte in forum Mitsubishi controls
    Last Post: 10-30-2012, 09:36 PM
  3. Bridgeport Interact 2 -- tachometer mode vs. voltage mode?
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2010, 07:24 PM
  4. Meldas 300: I can`t communicate with DNC mode
    By Meldas300 in forum DNC Problems and Solutions
    Last Post: 11-16-2009, 10:27 PM
  5. OKK PCV-50 Mode Select Keypad dead Meldas 320m
    By Monster_Shop in forum OKK
    Last Post: 10-11-2008, 08:46 PM
