586,117 active members*
3,488 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > 10"x12" Scratch built lathe
Page 3 of 9 12345
Results 41 to 60 of 169
  1. #41
    Dec 2009
    121
    Turret
    I just wrapped up the first side of the turret. I need to figure out how to port coolant to the active tool. If anybody has some neat ideas let me know.
    Scratch built lathe turret roughing - YouTube
    There are still a few ops to the reverse side and some rotary work to the sides, but all in all I think the turret is coming along nicely.
    Anybody know a good way to color the letters so that it doesn't get eaten by coolant?
  2. #42
    Jun 2004
    355
    Quote Originally Posted by jakemestre View Post
    You don't need anything fancy. Have a fixed port with seal (o-ring in a suitable groove that sticks out just slightly), then suitable drillings in the tool holder that align with the port and direct fluid to where you need it. You'll probably want to add either short flexi nozzles, or fisheye nozzles to direct the fluid to the cutting tip depending on the tool.
    The seal doesn't have to be perfect, as a bit leakage shouldn't be of any concern.
    If you really want to colour them, then find some oil resistant paint.
  3. #43
    Jul 2012
    29
    Jn
    Sent from my SAMSUNG-SGH-I317 using Tapatalk
  4. #44
    Dec 2009
    121
    Quote Originally Posted by clmenz View Post
    Jn
    Care to elaborate? lol
  5. #45
    Dec 2009
    121
    Turret check
    The turret is done, at least for now. There are a few things that bother me enough to potentially remachine the turret. The alignment was really hard to achieve on the 4th axis work. Next time around I'll do the 4th first (with a much sturdier fixture), then use the octagon to machine the stick tools in a cross pattern. The cross will eliminate the simultaneous x and y motion, and potentially help with the tool alignment. In the pictures you can see a notch in the slot to align round tool holders. That alignment slot is supposed to be flush with the face the stick tools sit. That little notch in the stick tool face is a source of much concern. The fact that there's even a notch says there's a misalignment problem, but worse is it's different on each tool. I'll continue on to the rest of the machine, but if I have issues with tool alignment I'll make a new turret. The programming was the most time consuming part, and luckily that's all finished for the next go around.
    Turret Hirth Pockets - YouTube
    The main plate has been out for stress relief the last few days. When it's done it'll go straight to a friends shop to surface/drill/tap for headstock, guides, and screws. When it's back I'll begin welding the stand. I ordered a Lista cabinet to build into the stand. The minifridge will go in the mill stand In the mean time I got the control boards from Mesa. 5i25 and 7i76 will be responsible for motion control. After having run mach on my current lathe I decided I wanted some of the features that LinuxCNC offers.
    That turret just made this project real, if you know what I mean. Everything is fine and dandy in the computer model but for me every project has that moment when you realize it's coming to life.
  6. #46
    Apr 2003
    354
    Jake, are you already Linux fluent? Please post your setup process when you get there. I'm using Mach & it's working pretty well so far but I'm not pushing it very hard & all weird behavior has been traced back to operator error.
    Awesome job you're doing...I'm enjoying every detail!
  7. #47
    Jun 2011
    695
    Nice job! Big hunk of aluminum.....all I could think was "one wrong G-code" = scrape!
    Next year I will attempt my own scratch built slant bed lathe,but will probably go with gang tooling. Same reason as you I need something better then my converted china iron.
    Thank you for creating this thread,yours is exactly what I'm thinking.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  8. #48
    Dec 2009
    121
    Quote Originally Posted by DICKEYBIRD View Post
    Thanks Dickeybird, Mach has some serious bugs with CSS and threading on a lathe. It's a great program and maybe in the future there will be a more stable lathe side, but in the mean time I'd love to rigid tap and thread withouth error. A single index on a spindle, while perfect for a mill, is less that optimal for a lathe where RPM can be changing by rotational degree.
    I'm not "fluent: with Linux but I can program in C++ if that's what you're asking. Linux or Ubuntu is really just an operating system not unlike the mac OS. It's pretty cool actually now that I've been playing around with it. I'll definitely keep the forum updated as I make progress with this system.
    Quote Originally Posted by FannBlade View Post
    Your CNC definition is AWESOME!
    No aluminum, all 4340 Steel. And yes, on the last op on the 4th axis the machine spun the turret and started eating the part. That's one thing about a slower machine is that you have enough time to hit the "Oh F*&@" mushroom button.
  9. #49
    May 2008
    1185
    I've been thinking of building a CNC lathe too. I have a CNC IH and a good size lathe but I need CNC for a few parts and I can't fit another full size lathe in the shop. I need at least a 6" chuck so I might just make a lathe. The lathe is not the problem but the CAM and controller software. I just don't like Mach3 so far for a lathe.
    I built a X-Y table to fit my lathe for practice and it works but I didn't get far with Cambam and Mach.
    Let us know how Linex CNC works for you and the CAM processes if you can.
    Dave
  10. #50
    Apr 2005
    419
    Your turret looks absolutely amazing. Can't wait to see how the rest of the build shapes up.
  11. #51
    Apr 2003
    354
    Yup, CSS would be nice but I get along OK without it. There's a guy on the Mach support forum that's written a CSS plugin but it's not all there yet.
    I think the threading problems were corrected around release xxx.052 or so. *BUT* it does require a stable spindle speed with lots of "grunt" to do threads in steel. Mine did great threads with the 3/4 hp DC motor/KB controller in acetal & aluminum but who needs aluminum bolts! I did some M22x1.5 threads in 1144 steel but had to use a very shallow D.O.C. & a zillion passes. Ended up finishing the job hand cranking the spindle on my other (manual) lathe.
    I'm getting close to completing a 1:6 belt reduction system for it now which I'm confident will take care of the problem. Be nice to have a 1000-1500W servo spindle drive but on my meager budget it ain't happenin'! If I was Linux savvy enough, a spindle encoder would work also but that ain't happenin' either.
  12. #52
    Dec 2009
    121
    Hey Guys, Sorry it took me so long to respond. I should get out of my shop every once in a while and check my own thread right?
    Quote Originally Posted by arizonavideo View Post
    Dave
    Hello Dave,
    Linux CNC is a useful way to control CNC machinery, not that Mach isn't a great tool. I'm no expert, so if one wants to chime in please feel free, but I believe the kernel plays a part in the motion of the machine. Windows XP/Vista/7 are based around a hybrid kernel which doesn't have soft or hard real time support. It also runs things in the background which can distract the OS from it's task of running the machine.
    Linux is a monolithic kernel which does allow for soft real time support. From what I understand the real time support allows for things like threading or CSS to happen much better than with Windows. Again, I may be totally off basis on this as I'm no expert. Bob has a great couple of blog entries on motion control with windows.
    Quote Originally Posted by 691175002 View Post
    Thank you very much! I'm excited to see how it turns out too.
    Hey Dickeybird,
    A perfectly stable spindle is something I just can't get to work. I've spent a huge amount of time playing with the VFD and mach settings, but I just can't get it to work perfectly. Based on my design criteria of +-.0002, I need to be able to hit a pitch every time. I think you're right about CSS for the most part. But if you've got a large diameter part, say 10", the surface speed for a facing op will change significantly. Better to design in the feature and not use it than to not have it when needed. From playing around with Linux so far, I don't think it's any harder to set up a machine than Mach. Just different. If you can build your own CNC you can definitely learn a new OS. lol
    Update to come shortly.
  13. #53
    Mar 2007
    304
    Great Build - and Thank You for sharing your decision making process.
    Will you please post your Turret Design when you are finished?
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
  14. #54
    Jun 2004
    355
    Hello Dave,
    The main difference is the kernal used for LimuxCNC is compiled so that it's main priority is dealing with the hardware and trajectory planning. Everything else, including display updating, is handled whenever there is unused CPU time.
    Windows on the other hand doesn't have that prioritisation, and the Mach 3 parallel port driver relies on a constant interupt (that's what the kHz settings are) to force windows into dedicating time to update the parallel port. However this relies on there being sufficient CPU time/power to deal with trajectory planning outwith the interupt handling, which is where Mach often falls over, so if windows decides something else needs CPU time, then Mach has to join the queue and wait.
    As for Linux being better for CSS, it's just to do with the software. Mach3 was never designed to do CSS, or lots of other things that it can currently do. It's constantly had bits patched on, and it's now reached the point that there's that many bits been added, that trying to add something else, or changing things often leads to lots of other things get broken. I'm pretty sure I read that trying to fix CSS was one of the final straws that finally forced Brian into starting to write Mach4.
    PS. Keep up the good work! I had subscribed to the thread as inspiration for a potential build, however having bought a Denford Cyclone a couple months back complete with tool changer, I now onlt keep following to see how you're build is progressing.
  15. #55
    Dec 2009
    121
    New update:
    Plate is back from the machine shop. I didn't have the size on the Tormach to get everything done with one fixturing. I really wanted to make as many components as possible in my own shop but sometimes you have to bring out the big guns.
    I'm really glad I took it to the shop I did, they suggested a small alignment ledge for the linear guides. If you only take one thing away from this build just remember to add an alignment ledge into every machine you build from now on out. It made aligning the guides a ten minute process. Both rails are +-.0001 over the entire length measured from the front edge.
    Lowered the supports for the X axis Ballscrew
    Machined the fixed end of the Z screw from scratch, modified the existing ball nut block to bolt to the axis sub plate, and modified the end support.
    X axis plate is machined and ready. The front linear guide bolts are round, fixed location bolts, and the back are slots to accommodate some miscalculation on my part.
    Starting assembly
    A little closer.
    Things move SO smoothly. It's amazing. I can slide the whole assembly by pushing on the x axis plate.
    The next steps are the build the housing for the turret, machine the second Hirth joint, build a stand, and build an enclosure. Oh, I think there's some wires that have to go in there too somewhere. Not to mention the spindle cartridge, and headstock.
    It's all in good fun.
    Thanks for reading,
    Jake
  16. #56
    Dec 2006
    73
    Ambitious (but very nice) project. Did the machine shop weld those rails onto the bottom plate? And machine them after they were welded? I assume the alignment ledge is the small lip sticking up on the back of each rail? I'm always hesitant about welding anything on a machine tool for fear of warping it.
    Chuck
  17. #57
    Dec 2006
    73
    Another quick question... Have you thought about how you will get the Y-Axis parallel with the spindle axis in all directions?
    Chuck
  18. #58
    Dec 2009
    121
    Quote Originally Posted by cffellows View Post
    Chuck
    Chuck
    Hello Chuck,
    I TIG welded the rails onto the plate and then I had it stress relieved. You can probably see the small segments of welding I was doing to try to minimize warping. I welded a couple inches on opposite sides of opposite rails and let everything cool between welds. The plate warped about 1/16" at the edges, but nothing a facemill couldn't deal with. That's the beauty of a scratch build is I can weld whatever I want wherever I want before heat treat. After stress relieving no more welding or the relief is negated.
    The small ledge at the back of the rails is indeed for alignment. Getting the X axis perpendicular will be more challenging. I know the x axis sub plate is square so if I align the front, which runs parallel with Z, relative to to the Z rails it should be square on X. We'll see how that turns out though. It's a bit hard to see in the photos but I also had the machine shop square the edges of the main plate. If I make a huge test indicator arm I can measure the x rails relative to the main plate edge behind the headstock. I'm learning as I go. Thanks for your questions. They keep me on my toes.
    Jake
  19. #59
    May 2013
    149
    Sublime!
    Wisdom results from foolishness!
  20. #60
    Nov 2012
    220
    I am enjoying your build, thanks for sharing!
    I have been looking at your design and I was wondering how you plan on mounting your flat plate? I do not see any mounting holes and I would assume you don't want to weld it at this point.
Page 3 of 9 12345
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Home Designed Scratch Built CNC Lathe
    By Chrisjh in forum Videos
    Last Post: 11-07-2013, 09:40 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Looking for Specs for a scratch built lathe
    By breathe in forum Vertical Mill, Lathe Project Log
    Last Post: 06-16-2011, 12:56 PM
