VMC15 computer crashed tonight. First time since new 11 years ago.
Screen reads "You must enter the backlash table. Jog axes to home then enter the CS command. No parameters or parameters corrupted. you must enter the setp command. Press any key to continue."
Jog handle drives xyz axes no problem. No keys respond on keyboard except jog key. Coolant turns on when space bar (?) is pressed. Basically can't do a cold start now, but did do a cold start on startup. All happened when editing a program, have not run machine in about two months prior to this. Severely bumming out...any help?
