586,788 active members*
2,882 visitors online*
    Aug 2004
    2849
    Hypertherm 1000 intermitten problems
    Here is what the seller claims: Hypertherm Powermax 1000 plasma cutter, was bought new in 2007 and was lightly used from that time but recently developed a problem, it begins to cut well for a while and then stops cutting and only sparks but does not cut and you let it cool down and it works for a bit again, i bought a new machine and don't have time to mess with this one.
    How much to fix this system? Is it worth $300?
    Paul
    Jan 2008
    2247
    It is worth $300 easily. I would have to ask a bunch more questions to get closer to the problem. As you state it...there could be a sticking plunger or an arced out plunger in the torch. Could be a worn out swirl ring or retaining cap. Could be a sticking air solenoid valve. Could be a loose wire connection.
    Jim Colt Hypertherm
    PS....if you are from Texas and tried calling me directly, I called you back 3 or 4 times, no answer and your voice mail was not functioning!
    Quote Originally Posted by ViperTX View Post
    Paul
  1. Hypertherm 1000 problems
    By Greg Westberry in forum Hypertherm Plasma
    Last Post: 10-05-2011, 01:27 PM
  2. Hypertherm 1000 problems...
    By monkeyevil in forum Waterjet General Topics
    Last Post: 03-10-2010, 01:57 AM
  3. hypertherm 1000
    By curlyweld in forum Hypertherm Plasma
    Last Post: 02-17-2010, 01:38 AM
  4. Use Hypertherm 1000 arc ok without THC
    By Wolfesmetalfab in forum Mach Plasma / Laser
    Last Post: 01-31-2009, 12:15 AM
  5. THC 300 and hypertherm 1000
    By Don C in forum Waterjet General Topics
    Last Post: 10-31-2005, 12:33 AM
