586,072 active members*
4,681 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > emco concept 55 mill startup trouble
    Aug 2013
    Hello all. i just got a emco concept mill 55. made in 2006. I have loaded the winnc on to the flash drive and plugged into the machine. All cords are connected to the right place. The monitor goes through the linux code. The monitor reads: finished update. then it asks for a username and password? Where do I get this? And I tried talking to the emco people but they are not responding.
    Sep 2010
    18
    Re: emco concept 55 mill startup trouble
    if you are still around! What linux code? - The clue is in the sofware name - 'winnc'...
    cheers,
    john
    Mar 2014
    44
    True. You dont use the Linux machine. You connect is to a windows machine with wincam/camconcept and that does the machine control. You just found the calculation unit of the machine. In the concept mill this is different from the machine control.
  1. Replies: 0
    Last Post: 08-16-2011, 11:22 PM
  2. emco Concept MILL 300?
    By byronk in forum EMCO CNC Machines
    Last Post: 02-17-2011, 11:04 AM
  3. WTB Emco Concept Turn 55
    By crucialthreads in forum Want To Buy...Need help!
    Last Post: 10-18-2010, 11:43 PM
  4. Emco Concept 55 Lathe
    By skinnekid in forum EMCO CNC Machines
    Last Post: 04-15-2010, 10:27 PM
  5. Emco Concept turn 55?
    By praetor in forum Vertical Mill, Lathe Project Log
    Last Post: 06-08-2008, 06:18 AM
