Attachment 196536The motor interface board tells the PUMA board how fast to spin the spindle. Eight wires encode the desired speed and two wires control the logic. I have diagrammed the board to make it easier to understand. There are 10 wires in the cable that attaches to this board. All of the wires are optically isolated from the rest of the board. The PUMA board is looking for an analog input. The chip sees the digital pattern from the cable and converts it to an analog output for the PUMA board. That output goes out the three wire cable to the screw connectors 1,3, and 4 on the PUMA board. Look up the specs on an AD558JN if you want to understand the magic.
If you want the short version, all chips run on magic smoke. As long as the magic smoke stays in the chip it will work. When the magic smoke comes out the chip is worthless.
