hello all,
a week ago i went to start up the machine noticed z axis wasn't homing correctly. turned it off opened up the cabinets. then turned it back on, noticed when i hit reset to turn servos on z axis card had the surge/ground fault light on. turned everything completely off and started checking connections at the card, looked fine. powered it back up when i hit the reset z axis ran away i positive direction
i then called zps for some trouble shooting switched the y wires over to the z card, y axis ran away. so z card has to be bad. said they would call me back if they still had one.
no call back, so i called a company i had seen mentioned here. the old card i had was servo dynamics 1525-10, they suggested the newer 1525 BR. long story short, the first one they sent done the same thing z axis run away, they seemed to think maybe i had been sent one that hadn't been tuned correctly. so the second one arrived, now the z axis creeps in the negative direction about 3/16 inch and stops and when hit e stop it creeps on down a inch or more. so now they are sending me an original 1525-10, my fingers are crossed.
my real concern here, besides the obvious, during some of the conversations it was mentioned i may have to do some fine tuning as far as "lag" goes. i do some 3 axis contouring. i'm a machinist not a electronic person. i do understand what a pot is on the boards. but even after it was rather quickly explained to me i'm not sure. how will i know if it even needs adjusted.
then i'm also concerned what caused the surge/ground fault to begin with?
if anyone has been through any of this your advice would be greatly appreciated.
thanks in advance
