586,033 active members*
3,515 visitors online*
    May 2013
    24
    A Simple Test?
    OK...brand new to BoCAD-CAM. So this will be a simple test. I have an oak table leg and I want to mill a groove(rectangular) in the top of the
    leg on the left side. See the image showing the machine simulation. The simulation shows the bit cutting the perimeter of the groove but does not
    clear out the inner material in the groove. It only cuts a rectangle in the top.
    So...what is my basic error here. I sure I must have made an erroneous selection...possily in the mill 3 axis menu?... or what?
    Jim
    Aug 2012
    621
    The operation you want for that cut is a Pocket, which will clear out the inner material to a selected depth. The Sim looks like you may have used a Profile cut, possibly? Profile just follows the geometry you select, given various offsets, etc. It won't get to the inside stock in a case like that. There are other possibilities, but given the info, that's a first guess.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    bobcad guy Guest
    I mostly agree with trot, but, I would use the advanced pocket, with a dashed line as the top of the leg geometry, thus making an open pocket strategy. just go to bobcadafterdark.com and watch als' open pocket vid. should clear up the problem
    Apr 2009
    3376
    Welcome to BoBCAD,if you would like to gain knowledge,I recommend http://www.cnczone.com/forums/bobcad...formation.html
    That link has tons of info.
    Dec 2008
    4548
    Could be just the "workpiece" is visible and you wanrt to see the cutout? STart the sim and clcik the show/hide workpiece once for transparent and twice for invisible.
Name:	workpiece material.jpg
  1. Simple G Code + tooling setup to test axis.
    By diyengineer in forum Benchtop Machines
    Last Post: 04-17-2013, 03:11 PM
  2. Simple Calculations for a simple mind.
    By cr8zy1van in forum Mechanical Calculations/Engineering Design
    Last Post: 11-04-2009, 10:12 PM
  3. Surface finish, another simple test
    By 1ctoolfool in forum Haas Mills
    Last Post: 11-25-2008, 03:02 PM
  4. Simple test axis
    By jfong in forum DIY CNC Router Table Machines
    Last Post: 05-14-2004, 03:35 PM
