I use 18i-TB Fanuc controlled CNC grinder with absolute motors' pulscoders. The machine has two sides (NC1 and NC2). NC1 controls grinding wheel position (X, Z axis) whereas NC2 controls the loader arm (U, W axis). The loader arm moves left/right (W axis) and up/down (U axis) passing a workpiece to be ground.
After setting loader W axis motor pulscoder zero postion (home) about 7mm from the left mechanical axis end, the machine runs for some time with no trouble. However after a few days I can hear some kind of noise and W axis motor current increases at the left end position. Then I check the axis zero point position vs. mechanical end and it appears that home point shifts itself a little beyond left mechanical end (collision!) about -0.7mm but it should be set about 7mm from the left mechanical end). So it moves about 7.7mm within a few days with no warning or alarm!
What may be wrong? I haven't changed any parameter or program of the machine.
The problem started a few months ago. Before that, the machine had been working correctly.
I replaced W axis pulscoder as well as cable between pulscoder and servo amplifier. Pulscoder cable connectors cleaning didn't help as well. Do you think I should replace W axis motor? I suspect that W axis servo amplifier controll PCB may be also damaged in such case.
At the moment, I'm forced to set zero point of W axis motor pulscoder from time to time when overcurrent (noise) is observed. It's burdensome.
Thx for help in advance.
