Last time I posted was in January, now its August.
Work was keeping me tired up solid until recently, my hours have now been cut which means I actually have time for "home work".
I got the machine moved into its final spot. Wired up the phase converter. Ran new conduits and power lines so I now have power at the magnetics side disconnect. I am eager to twist the switch - BUT I wanted to be sure all is Kosher in the PC side when I realised I AM LOCKED OUT.
Not sure if there is a way to look up the key pin code based on S/N, or is there a generic key that can do the job - or do I just break out the angle grinder and make a mess of things.
This realisation came about 6pm local time, so too late to call HURCO, and I'm not sure it would do any good, HURCO doesn't want anything to do with any machine with factory blue paint.
