586,115 active members*
3,372 visitors online*
    Apr 2013
    31
    2030 limit switch alarm
    I have a Chevalier 2040MV, 16 position tool changer (caroulsel type), Fanuc O-MD control. Getting a 2030 limit switch alarm which my manual says it is tool changer limit switch error. Both switches are fixed. Alarm happens after G91G28Z0 execution when the only movement is Z going home. Tool changer is still in the tool change position. Next command is T__ and then G91G30Z0. I transposed the two switches to make sure it wasn't the switch.
    Any suggestions?
    Jim
    Sep 2014
    4
    Re: 2030 limit switch alarm
    Quote Originally Posted by jschmid View Post
    Any suggestions?
    Jim
    I was curious if you solved your problem? I'm having the same problem
    Dave
    Apr 2013
    31
    Dave,
    Yes, the problem was solved. I had gone through numerous trial and error suggestions and the final fix was: Shutdown the machine, on startup, hold down the "P/Q" button and the "Cancel" button when you activate the control side, this clears all the faults. I had a tech from Spokane come in and fix my problem-15min fix.
    Jim
    Dec 2022
    I also same how i can solve this problem i want o one video
  1. Z limit switch alarm
    By guydrisc in forum Okuma
    Last Post: 01-22-2012, 06:29 AM
  2. X Limit switch '92 VF-0 103 Alarm
    By lkenney in forum Haas Mills
    Last Post: 07-05-2010, 04:57 PM
  3. TM-1 Y axis limit switch alarm
    By jwknow in forum Haas Mills
    Last Post: 10-26-2007, 09:53 PM
