586,075 active members*
3,674 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Adobe Illustrator Files
    Apr 2009
    3376
    I got a customer just called and said he will be drawiing something up the next few days.He has no experience sending files.I asked if he had .dxf and a few others.He said he did not think so.? ? ?I have no idea,,,he is there and I am here.I never played with Adobe Illustrator before.So anybody here have experience with that software and know what format at his disposal would be best to send me to open in BoB??This will be 2D.
    Jan 2011
    380
    Depends on which version of Illustrator he has. Newer versions support DXF and DWG but only as an 'export'. Won't find it under 'save as'. Tell him to check his export file options.
    Apr 2009
    3376
    Aha,,that's probably it.I told him there had to be an option for .dxf.Thanks Tony.
    Aug 2012
    621
    I think the native Adobe Illustrator format is .ai, and that's supported under BobArt. You have to look under the [BobArt Manager] tab, and click <Load Vector Files> to access it. I don't know how well supported .ai is, especially from version to version, but I think I'd at least try that. Maybe it'll be automagic!
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Dec 2008
    4548
    You could tell him to save the AI or EPS as "version 8". This should be generic enough to "warn him at export" if anything is being dropped or transformed. Then your both on the same page.
  1. Adobe Illustrator to VisualMill
    By gmesheau in forum Visual Mill
    Last Post: 03-23-2017, 11:29 AM
  2. importing from Adobe illustrator
    By fourperf in forum Solidworks
    Last Post: 11-29-2010, 08:43 AM
  3. Adobe Illustrator and TMcad
    By LenMcC in forum Torchmate
    Last Post: 03-30-2009, 05:59 PM
  4. Adobe indesign and illustrator
    By dpmulvan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2007, 08:31 PM
  5. Adobe Illustrator Files
    By JOE65 in forum Autodesk
    Last Post: 02-09-2004, 11:20 PM
