586,100 active members*
2,657 visitors online*
    Aug 2013
    Exclamation Heidenhain TNC 415
    Dear All,
    We had Boko make 5 –axis CNC machine.
    This machine have TNC 415 Heidenhain controller with siemens drive interfacing.
    We are facing problem of Display not getting On or system not processing/ booting.
    We had confirm that control On Push buttong voltage goes to PLC.
    But we had following observations.
    1) NC board power supply, 24V LED is glow, but 5V, +12V, -12V LED not glows.
    2) PLC board +5V,+15, -15 Volt supply not observed on checking test points.
    Please suggest solution
    May 2013
    128
    See the Mother board Box , Interface cable to Display , Only Display not works ? after Power on Rest buttons LED Lit or not ?
  1. Heidenhain TNC 145
    By rfarleman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-05-2010, 11:21 PM
  2. HEIDENHAIN-ISO
    By shafter in forum Bridgeport / Hardinge Mills
    Last Post: 03-27-2010, 07:44 PM
  3. Heidenhain TNC 620
    By cnc spook in forum Controller & Computer Solutions
    Last Post: 07-30-2009, 10:22 AM
  4. Heidenhain 145
    By kck63 in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2007, 01:25 PM
  5. Heidenhain 150 help
    By tom bryant in forum MetalWork Discussion
    Last Post: 05-19-2006, 03:53 AM
