586,100 active members*
3,115 visitors online*
Thread: Meshcam ????
    Jan 2013
    18
    Meshcam ????
    Trying out Meshcam and so far nothing but problems. When g code is generated it puts the part 588 inches off the table. I'm using an stl file that is in mm , I tell it to use inches and it asks me if I want to scale it down to 4 inches ,which I say yes. I've tried everything but still puts part way off table. Called Meshcam for help 2 days ago with no response. No acceptable tutorials also. As of now I give it a big thumbs down. Maybe after I talk to owner of software I will change my mind as I like the fact that it will do 4th axis work if I could get far enough to try it??? If some knows the owner please have him return my call as you can tell I'm a little irritated
    Sounds like your not setting up your stock correctly, or your part within the stock.
    Have you emailed [email protected] ?
    Have you asked on the MeshCAM forum. Lots of helpful users there that should quickly get you straightened out.
  1. Meshcam
    By speedtwin69 in forum Uncategorised CAM Discussion
    Last Post: 03-24-2013, 05:41 AM
  2. New To MeshCAM
    By cartman635 in forum Uncategorised CAM Discussion
    Last Post: 07-10-2012, 05:33 PM
  3. Meshcam Art?
    By rkd in forum Uncategorised CAM Discussion
    Last Post: 06-02-2007, 02:38 AM
  4. Anyone using MeshCam?
    By groomden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-26-2006, 01:07 AM
  5. Meshcam?
    By fattuna in forum Uncategorised CAM Discussion
    Last Post: 10-13-2004, 08:19 PM
