586,036 active members*
3,436 visitors online*
    Apr 2011
    31
    Encoder for EZ Path 2 trouble
    The Z axis on our lathe works on jogging and feeding. However, the manual wheel does not work. How does one test an encoder? I looked at the encoder and see that the cable is integrated with the encoder for I was hoping that there is a break in the cable itself, which is still possible. Thanks.
    Apr 2011
    31
    The electrician went to fish out the cable for the encoder and found a connector for it that had managed to unscrew itself and come apart. The connector for the X axis was about to come apart too. So, problem solved.
    Jul 2013
    24
    If the lathe jogs and feeds, it probably isn't an issue with the encoder or motor. I have seen in the Fanuc Beta Series a similar issue with the manual wheel where the drive's control board was faulty and gave us the same problem. If you can give me more information on the make and model number of the motor and encoder, I may be able to give you further information on your issue. You can contact me through
  1. trouble crating a tool path group
    By dcutler35 in forum Mastercam
    Last Post: 03-09-2016, 04:25 PM
  2. Trouble with 2D Contour Path
    By Anokiernan in forum Mastercam
    Last Post: 01-21-2008, 04:59 AM
  3. Yaskawa Encoder-DC Servo Motor trouble
    By nlh in forum Servo Motors / Drives
    Last Post: 11-28-2006, 03:58 PM
  4. Encoder Trouble HELP!!
    By ty1295 in forum CNC Machine Related Electronics
    Last Post: 08-05-2004, 11:47 PM
  5. encoder trouble
    By an0n in forum Gecko Drives
    Last Post: 04-20-2004, 06:39 AM
