586,060 active members*
4,125 visitors online*
Results 1 to 6 of 6
    Cut to the Bone Guest
    Black Box Vac
    Starting up a new product, with the help of an old friend.
    I know a lot of folks that have the need for a vacuum solution for single phase applications.
    So we are going to bring to market a vac box that we have revamped.
    This box uses 4 vac motors that work in tandem to create all most as much suction as a 15 HP
    Regenerative Blower Vac.
    more specs to come soon as well as price.
    I just wanted to see if there was any interest here. I have already taken orders for the system
    and know it will be a great solution for the small shop that has no 3 phase power. Also ones on
    a budget.
    The box will be completely assembled and wired. All you have to do is to run your PVC to it and
    create a grid on the table.
    This Box is designed to easly install on CAMaster machines. But will work with any CNC Router that will
    accept a Vac table.
    The system will run on 220v-230v 30 A single phase power. There is two stages to this vac. meaning that
    you can run just 2 of the motors if you only need the 2 or turn on the other 2 that will open an internal
    gate and give you twice the power.
    Please enjoy the attached pics and let me know if you have any feed back.
    * this system is not manufactured by CAMaster, inc. I build it in my own shop. I am in negotiations
    with CAMaster to offer this unit on there Stinger Series Routers as a great option for a low cost
    single phase vacuum.
    email me if you have any questions [email protected]
    Attached Thumbnails Attached Thumbnails 2013-08-20 14.46.04.jpg   2013-08-20 12.11.42.jpg
    Sep 2012
    11
    I'm interested if the price is right!
    with the gate valves (they will be black like the box not white as in the pic) $1995
    Without the gate valves $1795
    The box has a 6 foot cord with a twist lock plug. To add a 20 foot extension cord with male and female plugs $149
    I have the next 3 or 4 sold it will be next week before I can build more.
    We will also have 2 smaller units. A 3 motor and 2 motor option.
    Nov 2007
    2466
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    New site is up and running check it out.
    Black Box Vac Home
  1. How to tell the difference in Black ABS VS Black Delrin?
    By conceptmachinin in forum Material Machining Solutions
    Last Post: 10-17-2011, 03:43 PM
  2. 0MD black out
    By samu in forum Fanuc
    Last Post: 10-12-2010, 08:43 PM
  3. CRT color, became black
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-14-2009, 01:50 AM
  4. More monitor black out
    By Kool Parts in forum Haas Mills
    Last Post: 10-28-2008, 03:22 PM
  5. WHO Does Black PVD?
    By mabmojo in forum Material Machining Solutions
    Last Post: 09-25-2008, 03:56 PM
