586,419 active members*
2,862 visitors online*
Results 1 to 9 of 9
    Mar 2006
    115
    Question Genicom Stepper Motors
    Hello all,
    First let me warn you. I am new to the CNC world and am still in the discovery phase.
    I parted out Three large Genicom printers. These both had 2 fairly good size stepper motors in them. One of which was labeled well but the other with just a manufacturer and part number.
    This motor is a Kollmorgen PJT80A2-24A, now through searching the forums I found a datasheet that has a PJ80 (A1 and B1) secifications on it. Is this the motor I have and can I use this data? If not, does anyone have the specs for this motor?
    Warm Regards,
    Joe Hildreth
    :cheers:
    Jun 2005
    5
    I have 15 of these. Did you find out anything on them?
    Mar 2006
    115
    I used a PJA2 specs for them. Do you need a copy?
    Joe
    Jun 2005
    5
    Joe,
    Please. Do they work well for you? May I ask what you use them for?
    James
    Mar 2006
    115
    I used three of these motors on my original JGRO router build. I used the spec sheet from the PJT80A2 because that was the closest thing I could fing. That seemed to work fine. Using 3/8-16 threaded rod with antibacklash nut made from the plastic cutting board material and lovejoy couplers, I could get about 30ipm from them using half stepping. The driver was a HobbyCNC 4AUPC controller. Started with TurboCNC I think and now use LinuxCNC. Let me look for the spec Sheets and I will attach them. I think they are on my home computer but may have a copy on my work computer.
    Joe
    Mar 2006
    115
    They must be on my machine at home. A search isn't bringing me anything up on the net either. I have set an alarm on my phone to remind me to get them and attach from home tonight.
    Joe
    Mar 2006
    115
    I had to look a while, but I found the spec sheet for the PJ80 genecom (kollmorgan) motors. I hope you find them helpful.
    Joe
    Attached Files Attached Files
    Jun 2005
    5
    Thanks. Greatly appreciate. I will let you know how I make out.
    Mar 2006
    115
    James,
    You are welcome. If there is anything else I can help with, let me know.
    Joe
