586,461 active members*
3,468 visitors online*
Thread: PCB Drills
Results 1 to 8 of 8
    Jan 2006
    67
    PCB Drills
    Just getting ready to drill my pcb boards but need to order drills. Problem is I can't find any reference as to what size drills to use. Know it probably depends on components being used but is there one basic size that is acceptable?
    Aug 2004
    3215
    I think people use 0.6mm or a 1/32" bit, but don't quote me as i have never made one.
    Joe
    Feb 2006
    77
    Hole through chip, resistors and capacitors normally are drilled 0.7-0.8mm, TO220 housings like 5 volt regulators are 1.0mm. You can buy them in HSS or Carbide. HSS lasts approx. 600 holes. Make life easy and use a (mini) drill-press.
    Aug 2004
    3215
    oops meant to say 0.8mm 1/32"= 0.766mm
    Mar 2007
    drills
    goto welding suppler get torch tip cleaning drill bit .
    littledrikk bitsto clean actaline torch or gas welders
    Jun 2003
    3312
    .032 #67, is a common usage size for resistors and capacitors, DIP packages,
    larger resistors will take a .042 #58 same for TO-220. Diodes many take an .046 #56. Components are different, I start out with .032 because only a few components need drills smaller, and then usually the .032 isn't a problem for those. I'm really getting to like surface mount and saying the heck with drills!
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Dec 2005
    1408
    Quote Originally Posted by Carel View Post
    Dear Carel,
    Excellent advice. Could I add a little?
    0.8 and 1.0 mm holes cover most through hole components. If you have discrete wire screw-down PCB connectors, you may need 1.3mm as well.
    0.6mm holes may work for most DIL chips, but I tend to avoid them. Too easy to break. Go for 0.8mm instead.
    If you are mounting the board on pillars, 3mm holes might also be useful.
    Those four bit sizes may not be all that you need, but they are a good start IMHO.
    It really helps if you have put a small "hole" say 0.3mm diameter at the centre of the pad on the PCB artwork. This helps you centre the drill bit if you drill by hand, either "freehand" or in a small drill press. I've never had much luck "freehand", but plenty of people have.
    If you have to increase the diameter of a hole that you have already drilled, be extra careful. That is when I always break small dia. bits.
    One more thing.. it is vital that the size of the pad is large enough to leave a reasonable area of copper after the hole has been drilled. If you do not, when you try to solder the component lead, the copper pad may lift off as it gets too hot.
    Best wishes
    Martin
    May 2003
    550
    Quote Originally Posted by aggie_67 View Post
    Harborfreight has recycled carbide bits from the pcb industry. Work great;
    http://www.harborfreight.com/cpi/cta...emnumber=44924
    recommend using a drill press or cnc machine, freehand will break them..
