586,080 active members*
3,571 visitors online*
    Dec 2008
    11
    Question How to Change B-Axis Rotation Limits?
    I'm trying to change the B-axis limits of a 5-axis CNC mill run by Sinumerik 840D from -5° to 110° to -110° to 110°. The machine hardware is capable of this, but at present the machine is limited to -5 due to a tool probe mounted there. The probe will be removed as it's not needed any more (replaced by an external too setting machine).
    I know how to move the hardware limit switches. I was able to locate two parameters in the control controlling software limits, but there mus be more as just changing these results in a bunch off error messages on power up, including some checksum errors somehow related to the b-axis. I guess the problem is related to 'safety integrated'.
    Dose anyone have an idea how to properly change the axis limits?
    See you
    Flo
    Oct 2009
    42
    What kind of machine is it?
    Dec 2008
    11
    it's a Spinner U620 whit a Sinumerik 840D controller (5 axis simultaneously).
    cu
    Flo
    Oct 2009
    42
    Your machine is about identical to mine, I have a DMG DMU 50 in the 3+2 config (no full 5 axis only positional). I guess i would call the machine tool company and see if that is even possible. Maybe pull up some prints of the machine and see if there is something mechanical that would keep from swinging the B axis that way. Also why do you want to swing the machine the other way? You can still get to five sides of the part by only swinging in the positive direction.
    Dec 2010
    50
    I would agree with ktmktmman. Contact the machine tool builder and see if what you want to do is possible.
  1. VH 65 A axis rotation
    By timo2le in forum Fadal
    Last Post: 09-08-2018, 10:13 AM
  2. trunnion rotation limits
    By zcnc4u in forum MadCAM
    Last Post: 12-04-2012, 02:23 PM
  3. how to set 4th axis rotation limits?
    By dwneumann in forum MadCAM
    Last Post: 09-13-2012, 08:54 PM
  4. A axis rotation ????
    By dunnitagain in forum Fadal
    Last Post: 07-29-2011, 01:50 AM
  5. B axis rotation
    By fitzpatrick2362 in forum MetalWork Discussion
    Last Post: 10-12-2009, 12:06 PM
