I tryed to do a canned cycle face feature and the code goes weird. You will see that my setup UCS is align with the backface of my rod, which is turned in a precedent setup. See the last pic.
First pics is my curve
Second pic is the code in canned cycle. See the coords before the g72? The z-coord is suppose to be something like Z3.75 but it code Z0.1.(take in consideration that I have canned clearance of 0.1 in X and Z.)
Third pic is the code without canned cycle. The starting coords looks very good in this patern!
I have knowledge on customizing post-process but can't find a way to correct this.
Ok, you will tell me, why would you spend time to correct something instead of using a simple feature? The reason is I customize my post-process to work perfectly as I want with my Haas lathe so I would not have to correct anything in the code in any feature. Most of the post-processor is done except this part that is a pain in the ...!
