586,072 active members*
4,594 visitors online*
    Mar 2012
    45
    MELDAS 64S M01 OPERATION ERROR 0004
    I HAVE A CONTROL UNIT MELDAS 64
    I HAVE CHECK:
    1. As the interlock function has activated‚ release it before resuming operation.
    2. Check the sequence on the machine side.
    3. Check for broken wires in the interlock signal line.
    Do not see any unusual problems
    I HAVE A M5PLCWIN CONECTION WITH NC UNIT MELDAS 64S BUT WHEN RS 232 COMMUNICATION
    I DO NOT UNDERSTAND PLEASE SEND INSTRUCTIONS MANUAL M5PLCWIN
    MAIL:[email protected]
    THANK YOU VERY MUCH
    Nov 2018
    Quote Originally Posted by CNC Machine OT View Post
    I HAVE CHECK:
    THANK YOU VERY MUCH
    have you solved this problem? Have a machine with the same issue
    Jul 2010
    9
    Hello friends,
    I have a problem will my moriseiki Tv-400 with MSC802(50MM). I am gettin alarm M01Operation error 0106 4th axis selection during magazine zero setting. I went to adjust mode made M3148 to 1 then made 6440.2 to 1 select c axis but same alarm appears. Can any one help me
    Dec 2020
    8
    Re: MELDAS 64S M01 OPERATION ERROR 0004
    Hello!
    Did you find a solution?
    I have the same problem.
    Dec 2020
    8
    Find the solution! First schould press H (handle)on the screen, than swich the axis selector to c!!!
  1. Mitsubishi Meldas 50L for Daewoo - Operation Manual
    By FMJ in forum Machinery Manuals / Brochures
    Last Post: 05-16-2018, 04:32 AM
  2. Takumi MCV 1100 - Mitsubishi Meldas 500 - Not Run - Operation Status (ST1) EMG
    By raghavansa in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-19-2015, 06:47 PM
  3. Meldas 50m - Error P460
    By droid in forum DNC Problems and Solutions
    Last Post: 11-08-2010, 11:52 PM
  4. M01 Operation Error 0101 on Mitsubishi Meldas M50 control - help!
    By SRT Mike in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-16-2009, 02:33 PM
  5. Bus Error - meldas 500
    By L. Sakthivel in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-04-2008, 04:01 PM
