586,080 active members*
3,475 visitors online*
    Apr 2013
    162
    What software works with a Mesa 7I76E?
    The 7I76E has all the features of the parallel port connected 7I76 plus more including two headers for connecting other Mesa daughtercards. Instead of the parallel port it has an Ethernet connection.
    The price is the same as a kit with a 5I25 (PCI) or 5I26 (PCIe) "superport" card and a 7I76 board with connecting cable.
    The downside? LinuxCNC currently doesn't support using Ethernet connections (or USB).
    What CNC software does support Ethernet connected step/dir boards like the Mesa 7I76E?
    Sep 2008
    229
    LinuxCNC has some (experimental) support for the 7i80 on ethernet and I would expect the 7i76E to work (once past the transport layer it all looks the same to the LinuxCNC drivers). LinuxCNC Documentation Wiki: Mesa7i80 Driver For Linuxcnc On Xenomai
  1. Any current software that works with a Compumotor 500?
    By Galane in forum Uncategorised CAM Discussion
    Last Post: 04-05-2013, 11:27 PM
  2. what CAD software easy to works with mach3
    By Nilesh in forum DIY CNC Router Table Machines
    Last Post: 07-01-2012, 02:51 AM
  3. Machine works, now the software..
    By rwijbenga in forum Uncategorised CAM Discussion
    Last Post: 12-28-2011, 04:51 PM
