:tired: Hopefully someone can help me with this. I have 3 Tormach steppers on a 48x96 router. Here are the motor specs:
Holding torque-Nm (oz/in) +/- 10% - 8.7 (1208)
Rated voltage - 2.7
Rated current per phase (amps DC) - 6.0
Resistance (Ohms) +/- 10% - 0.45
Induction (mH) +/- 20% typical - 5.1
Motor length (mm) - 118
Rotor inertia (g-cm^2) - 2700
Weight (kg) - 3.2
I am using a 60 Volt 12 Amp power supply with 3 Gecko 202's. Using a CNC4PC breakout board, charge pump and 5V/12V mini power supply. Geckos are sitting atop of very large heatsink fans which keep them vey cool. All my wiring is very neat with no power or motor cables near my step direction wires. All of my motor cables are shielded 18 AWG all my home and limit switches are 22AWG. My motor cables are about 22 FT. long. I am using Mach3 on a 650MHZ PC with 128 Meg Mem. I have Mach3 set at 35000khz and it displays a consistent 36152khz and I have used it at 25000khz and have not noticed any difference. With all that out of the way my problem is that I can run my router anywere from 20 to 80 ipm and it runs fine for about 15 minutes and then it starts missing steps. I notice that the motors start getting warm when this happens but by no means are they too hot to touch. Also the Gecko's get warm but just barely above room temp. I am checking them with a temp laser. And I had previously blew a couple of drives so I am being overly cautious and using 1 Amp fast blow fuses so I don't think I am drawing to much current. So anyhow I can let the machine sit for about 30 minutes and fire it back up and it will run fine for about 15 minutes and got to crap again. Mechanically the machine is very acccurate and will hold +/- .002 all day when not missing steps. All axis move easily with very little friction. I don't know if it matters but the programs I run are quite large and fairly intricate 3D. Anyhow I am just about at my wits end. Could someone please help me out. Hopefully Mariss will read this and bless me with some of his wisdom.
Thanks in advance.
