586,061 active members*
4,379 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 15 MB control saving ladder diagram to a PMC cassette. HELP!!
Results 1 to 7 of 7
    Jul 2013
    12
    I have very little expirience with this fanuc control. So far I have been able to write small ladder logic programs right on the machine itself. Does anyone know if it's possible to save the program to a pmc cassette such as (A02B-0094-C103)? What other options do I have? Any help would be greatly appreciated.
    Aug 2007
    793
    I think you must have PG-Mate. It is a "PC" from Fanuc
    Jul 2013
    12
    Thank you Guhl for your feedback, I have a P-Model G Mate I'll try it after lunch.
    Feb 2011
    640
    I dont recall the cassette/board numbers, but to do the small 15A cassettes on a pcwriter (or side door socket of the p-g mate) you need a adapter...I never tried the adapter in the side of the P-G mate, not really sure if it will clear to plug in either... my memory is getting bad, right now cant even remember if the A/B use the same cassettes
    On the series 15MB the ladder is stored in FLASH memory. You don't need any special Fanuc equipment to save your changes permanently. After you have made your changes on the PMC side select I/O.
    Writing data to Flash Memory
    DEVICE Press the [F–ROM] soft key.
    FUNCTION Press the [WRITE] soft key.
    Press the [EXEC] soft key to start outputting data. (Saves ladder edits to FLASH Memory (FROM)
    Apr 2010
    58
    hi friend
    the fanuc pmc cassette c (A02B-0094-C103), in it , there are two eprom . you can see it .
    pmc program is in it .
    you can use fa-writer or pg-mate can reade or writer it .
    but now you maybe can use convert tool for fanuc 15 series .
    Jul 2013
    12
    I was going to try to write to the F-rom but it is not an option on my system all I have under the I/O key is "print, FDcas, RamBD, Romcas, and Param."
    Now I'm trying the pg programmer, but cant get it to talk. Do I need a rs485 with this or 232? I don't have a manual for this programmer, Its a P-model G mate.
  1. Moriseiki SL6 Ladder Diagram - Fanuc 6T
    By gowthu in forum Fanuc
    Last Post: 05-29-2022, 09:48 AM
  2. Fanuc 11m Ladder diagram
    By Selimsalim in forum Fanuc
    Last Post: 05-22-2012, 05:40 PM
  3. Ladder Diagram for Mori Seiki MV40/Fanuc 6M-B
    By Randy K in forum Mori Seiki Mills
    Last Post: 03-06-2012, 11:21 AM
  4. Fanuc 16T Tornos ENC-167 ladder diagram
    By Jung in forum CNC Swiss Screw Machines
    Last Post: 11-19-2010, 08:49 PM
  5. LADDER diagram Fanuc OT
    By tano in forum Fanuc
    Last Post: 09-06-2010, 03:58 PM
