586,103 active members*
3,648 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 1981 Kitamura M-2 Fanuc 6M-B YZ Simultaneous Movement
Results 1 to 17 of 17
    Mar 2006
    28
    Hello-
    I was warming the spindle up on my 1981 Mycenter 2 Fanuc 6M-B in MDI in the 2nd Command screen using only S and M commands. When I went to home the Z axis both the Z and Y axis moved together. Not sure what happend. Has anyone had this experience before?
    Both axiis move independent of each other when programmed in Edit mode, but in Manual Pulse, Jog, Rapid and Homing they move together.
    Any ideas are welcomed!
    24221
    When you use the home routine, do you have to hold the respective button on all the time untill homed?
    The reason I ask is that in the edit mode, it is purely a software command, but in the rest, it involves hardware input which might suggest the Z & Y are being selected simutaneously, possibly by wiring malfunction/short etc.
    You never mentioned the control going in to alarm, so it appears the control thinks this is legitimate operation.
    Alot depends on just how the machine tool builder implemented the hardware/input,(if he did not interlock anything).
    Failing this, it could be a firmware fault on the servo IC's on the MB, but due to working OK in RUN does not seem to point to this.
    Most of the harware fault suggestions can be detected by use of the Diagnostic I/O table.
    Al.
    Albert E.
    Mar 2006
    28
    Al-
    When homing each axis via the homing selector position YES I do have to hold the + button down until each is zeroed out.
    Correct also that I am not receiving any alarms.
    Should I start by removing the Pendant panel and see if there are any crossed wires or am I to look somewhere else?
    Each axis was working perfectly fine and independently before yesterday's occurrence.
    Thanks Al.
    Matt
    24221
    If you have an axis selector switch etc, I would look on the diagnostic screen for the I/O and see if the respective switch inputs register on/off and if any are not simultaneously on.
    Al.
    Albert E.
    Mar 2006
    14
    If I remember correctly the selector switches in the pendant are connected to a circuit board and from there a multi core cable runs back to the cnc control. We used to have a problem with the solder mask on this circuit board coming off and corrosion shorting the tracks together. A quick rub over with a brass brush (power off) and a coat of varnish did the trick. If the selectors are connected with a ribbon cable look for signs of arcing where the ribbon enters the connector. The system is only meant to home one axis at a time. PS if an axis is already at home but requires rehoming if you select the -ve jog button the axis will jog off and back automatically.
    Mar 2006
    28
    Thank you both Al and Allyd-
    So far I have:
    1. Checked the selector switch on the pendant...it looks good but I will clean the contacts to be sure.
    2. Looked through my DGNOS screens and found the following "flickering" numbers:
    195, 196, 197, 238, 239, 704, 713, 714, 800, 801, 802 & 804.
    I do not have the correct Fanuc 6M-B Maintenance Manual for my machine and still wouldn't know what to do with these numbers if I did!
    NOTE: By "flickering" I mean multiple numbers in every string are flipping between 1 and 0.
    In my PC Parameters #195 is the only parameter to be blinking this way, but in my diagnostics pages the numbers listed above are all flickering.
    Any suggestions are welcomed!
    24221
    I don't have a 6m manual here, I have one at the shop tomorrow, but on the i/o diagnostic page, probabally the first screen, you should see the push buttons register when you push them, push and hold them and the bit should change from 0 to 1 and stay as ling as the button is pushed. make sure that the XYZ select button goes on to off as you rotate it. This way you can identify each function, This is why it helps to have the i/o listing for the address of each function.
    I wil also look them up tommorow.
    Al.
    Albert E.
    24221
    I happened to be at a customer today with a Kitamura M4 with a Fanuc 6M so it is probabally a similar machine, unfortunately he could not find his electrical prints but I checked the Diagnostic screen and it appears the jog and home buttons are common to all axis so it pretty much only leaves the Axis Select switch.
    The inputs on his machine were:
    X 40.4
    y 27.4
    Z 29.5
    A 23.3
    They are all over the map, I expected them to be together.
    Anyway, only one of these four should on at any given time. If two or more are on, that is your problem.
    Those byte address are 0 to 7 from right to left. e.g. 40.4 is word 40, 4= fifth bit from right.
    Al.
    Albert E.
    Mar 2006
    28
    Thank you Al so much for your time. I will report back after I have gone through the process.
    24221
    Quote Originally Posted by TFGC
    What happened to the report?
    Al.
    Albert E.
    Mar 2006
    28
    Sorry al-
    I had my electrician spray the contacts on the XYZ selector switch and it seemed to do the job.
    Now though, my ATC carousel spins non-stop when the manual ATC rotate button is pressed once. Do you think this switch needs to be cleaned as well?
    24221
    Sounds like it is sticking on?
    Al.
    Albert E.
    Jan 2006
    59
    Either it is the push button or the contactor is stuck.
    Mar 2006
    28
    The button does retract out after it is pushed though as opposed to staying in. Are there any sensors on the ATC carousel that could be "gunked" up so as not to be "seen" for positioning?
    I will check the pushbutton next to be sure there are no wiring problems. Can these pushbuttons be sprayed with contact cleaner w/o harm?
    24221
    Check for proximty sensor adjustment, see PM for cleaner.
    Al.
    Albert E.
    vfsi Guest
    Fanuc 6M-B Question
    I had a DC Velocity Control unit fail. So I swaped it with a spare the Axis works fine except, I have to limit the rapid speed to 50% or the DC Velocity Control give an Overcurrent alarm. I believe the DC Velocity Control is a fully functional unit.
    Do I have to (can I ) adjust the Overcurrent alarm via one of the potientometers on the top board?
    The manual that I have references Overcurrent alarm adj
    POT RV3 settings and check 10 Scales 0M-20M 2 + 3.8x scale(A)
    I assume 0M-20M is the motor size? and 10 Scale is the total number of divisions on the POT and the 2 + 3.8x is the range of POT wiper position?
    Do I need to measure a voltage on some test pin?
    Can anybody lend some clairification?
    Thanks in advance
    vfsi
    Mar 2006
    28
    Thanks all for the help. Seems that at the back side of the pendant a connection had worked loose through vibration. Once it was seated correctly it fixed my rpm spindle meter, tool carousel and spindle load meter problems. Hope this helps someone else!
