My second CNC machine (4' x 6' built into a 4' x 8' wooden work table) originally had two low cost 72" racks from McMaster-Carr. Those racks had cutter burrs on top of each of the teeth. I used a fine cut mill file to surface plane the burrs down just enough to remove the burrs - but not lower the teeth. That significantly quieted the noise while traversing but they were still noisy. This was way back just after CNCRP released their first r&p drives. I didn't notice any accuracy problems at that time though.
After a few months I laid out a steel box tube frame of 5' x 12' size and ordered four racks from Dianne at Moore Gear. Moore Gear's racks had no burrs and appeared to be made of much higher quality steel and machining finish than the low budget ones from McMaster-Carr (that I still have in storage). Don't skimp on money and buy the low budget racks. McMaster-Carr sells much higher quality racks.
I recommend Moore Gear as a very good source for the racks. Look them up online and call them to ask any questions you have. They have some useful specifications and documentation on their site as well. These racks have caused no problems with noise or accuracy since installation. However, I don't do anything with this machine where being off by a couple of thousandths over 6" distance anywhere on the table is anything to worry about.
Ballscrews will give you better accuracy, but with lower speeds and shorter travel lengths. There's always trade-offs that depend on what you want the machine to be capable of.
CarveOne
http://www.carveonecncwoodcraft.com
