586,106 active members*
3,105 visitors online*
Results 1 to 9 of 9
    Nov 2007
    188
    2600SY offset problems
    Just got a new 2013 2600sy Fanuc 31i with sub live tooling the works and when you go to measure tools on the probe you bring the probe down it jumps to the offset for tool that it is indexed too on my 2500sy parameter 5005.5 set to a 1 will let me move to what ever offset I want so I can have a offset for the tool facing the main spindle and a offset facing the sub because I have holders that have tools on both side. I ask the tech that came in and set out machine to change this machine to work like my 2500sy and he tells me they took this option out of this model and it will he will need to change the ladder to make it work that way I just cant believe that they would change something like this any body else run into this?
    2932
    I may be wrong, but 5005.5 is still QNI, so the 31 should be able to work exactly like your 18i when the Q-setter is used.
    From the 18i parameter manual:
    QNI The direct input of tool offset value measured B function and the
    direct input of offset value measured B for 2-spindle lathe:
    0 : Not automatically select the tool offset number
    1 : Automatically selects a tool offset number
    From the 31i parameter manual:
    QNI With the tool length measurement function, a tool compensation
    number is selected by:
    0: Operation through the MDI panel by the operator (selection
    based on cursor operation).
    1: Signal input from the PMC.
    Nov 2007
    188
    This is odd with the Q setter up I change QNI to zero put the Q setter down and I can move to a different offset but when I raise the Q setter back up it changes QNI back to 1 by its self
    2932
    Just for grins, have you looked at all the Keep Relays listed in the blue "Bible" to see if maybe one of them might control this behavior? I don't have a copy, but you never know... worth a look.
    2932
    Apparently it does require a ladder mod to change this. Your dealer should be able to get this taken care of for you.
    I'm with you... seems like a pretty drastic change that really didn't need to be made. Maybe someone crashed their machine by setting 5005.5 = 0.
    Nov 2007
    188
    Well it did take a ladder edit to fix it I sent them my ladder they edited it an sent it back now when I set QNI to 0 it stays seems like the newer a machine is the harder they make it to use.
    Nov 2010
    33
    the new puma 2600sy has a few extra built in safeties, i would like to think due to advanced technology as well as a decline in skilled labor in machine shops. Parameter 5005#5 is controlled in the ladder. There is an option for a switch to select manual offset select, x54#1 is the address for the switch. you can w search addresses r1396.0,r1396.1,r514.1,r604.2 and r604.3 to see how they intend for this function to be used. Your dealer likely removed the 11 nets for this from your ladder to make it like your older machines. Machine tool builders and control manufactures are constanlty working together try to prevent damage to machines and employees. We are starting to see machines running redundant ladders, redundant e-stop circuits and multiple pilz units on new machines. i know fanuc, siemens and heidenhien have this available. Unfortuantley we learn about these things as the machines hit the floor.
    Jul 2005
    380
    Quote Originally Posted by dcoupar View Post
    That's exactly what happened.
    Mar 2004
    44
    Re: 2600SY offset problems
    Noticed this on our brand new 2600sy ii this week. Not going to change it right away as it doesn't take much to manually input the required numbers for what I usually use this for; namely, rough boring with an insert drill. Good to know it can be done though.
  1. Fanuc 31i-a Doosan 2600sy alarm 2149
    By vf1kf in forum Daewoo/Doosan
    Last Post: 05-15-2013, 10:41 PM
  2. Programming Puma 2600sy
    By Drake75 in forum Daewoo/Doosan
    Last Post: 11-17-2012, 05:23 AM
  3. Fanuc 21T offset problems
    By mt92 in forum Fanuc
    Last Post: 05-04-2012, 09:41 AM
  4. Problems with Offset surface
    By 69owb in forum BobCad-Cam
    Last Post: 08-17-2008, 02:06 PM
  5. Roland JWX-10 Offset Problems
    By lfbrown in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 05-15-2007, 06:02 AM
