586,108 active members*
3,100 visitors online*
    Mar 2012
    29
    D.I.Y fridge compressor as air assist?
    does anyone know if a fridge compressor is suitable as an air assist?,
    is the flow strong enough?,
    thanks in advance,
    No, they can't be used for continuous use (they get quite hot). I used them to inflate bicycle-tires but even that was too much for them eventually.
    A big aquariumcompressor (for bigger outside pools) can work for longer periods / contiuous and can produce quite an amount of air if you use wide tubes where possible.
    they operate as quiet as refridgerator-compressors..
    Kees
    Yes and no, you can build silent compressors using fridge pumps but they give out quite dirty air and require a few of them to be daisy chained to get enough volume(and stay within the duty cycle). Pressure wise they can go to 600 - 700 psi so a good air receiver would be required.
    The clarke series of Shhh compressors effectively use fridge pumps but are expensive to buy.
    cheers
    Dave
  1. Laser Air Assist Compressor
    By c.fehringer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-02-2012, 02:38 AM
  2. i need to cool down my cnc lathe's electronics. Will a usb fridge work?
    By jasminder in forum Want To Buy...Need help!
    Last Post: 10-20-2011, 05:23 AM
  3. What is air assist?
    By greif in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-08-2009, 09:13 AM
