586,108 active members*
3,168 visitors online*
Results 1 to 2 of 2
    Aug 2004
    19
    Square stock only?
    Can't I start with a sphere, or a forging or casting?
    Very little of my work is based on a rectangular piece of stock to start...and I don't want to be cutting air.
    Jan 2006
    2985
    I have used this workaround in the past.
    Start with square stock.
    Make an operation to remove all the stock from the square so it loosely follows your actual stock shape.
    Do your normal operations to actually machine the part.
    When you post your code, don't post that first operation and then you will not be cutting air.
  1. square stock
    By 707Chipper in forum Benchtop Machines
    Last Post: 02-03-2012, 04:28 PM
  2. square stock to a small table leg
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 02-16-2010, 06:48 AM
  3. Machining square stock on a CNC lathe
    By premier_industr in forum MetalWork Discussion
    Last Post: 05-03-2009, 07:25 PM
  4. Centering square stock with a 4-jaw chuck
    By farmboy in forum Uncategorised MetalWorking Machines
    Last Post: 04-26-2009, 06:06 AM
  5. Radius on the corner of square stock
    By ErnieD in forum MetalWork Discussion
    Last Post: 03-31-2008, 03:35 AM
