[B]** Auto Tool Zero Sensor & Connection Checker. Tool Change, Measurement.[/B]
Click here -- Auto Tool Zero Sensor & Connection Checker
1. Check out whether the body of engraver is connected with end-mill electrically using checker.
2. Connect the GND to body.
3. Put the sensor under end-mill.
4. Link with your Breakout Board (Black : GND/White : Input). It’s ok to join to other connector.
If the GND wire & Sensor don’t contact, never turn on LED in Board.
If the GND & Sensor Contact, LED is turned on / Normal.
5. Measure Tool Sensor’s height precisely.
6. Set-Up in Mach.
Config -> Port & Pins. Set “Probe” in Input Signal as follows.
If used other pin, input the pin intead of it. Apply --- Check.
Go into the picture below in Mach. If the GND wire & Sensor don’t contact,“Digitize” is Off.
Check “Digitize” is On/Normal. Click “Edit Button Script” in main Mach Screen.
And “Auto Tool Zero” Button will flicker. Click this.
If a new window shows up, input the code below. Every Set-Up is finished after saving.
7. Operation Test.
Put the Sensor under end-mill and click “Auto Tool Zero” button in Mach.
The Z axis will go down while sensing. You can know that end-mill stops onto10mm in surface.
* Wire Length : 3M
** Stepping Motor Events !! Big Sale !
Click here -- Best Offer Products, Cnc4youstore
