586,392 active members*
2,968 visitors online*
    Aug 2013
    Discussion.......
    Hi .......................
    Plz tell me wats the diffrence between Rigid tap & Flotting tap
    1943
    A rigid tap is held in the toolholder in a manner where it cannot move in any direction. In a floating tap holder the tap can move a little in or out in the axis direction. This movement is spring loaded. For rigid tapping the feed rate has to be synchronized with the spindle. With the floating tap, the feed rate or spindle speed still have to be close, but if one or the other is off a little, the spring loaded movement takes care of it.
  1. Quite surprised at how little discussion is here...
    By mcphill in forum FlashCut CNC
    Last Post: 05-16-2012, 01:16 PM
  2. discussion of machine
    By sunitas in forum Wood Lathes / Mills
    Last Post: 11-27-2009, 11:31 AM
  3. DIY CNC Technical discussion
    By llilrex in forum DIY CNC Router Table Machines
    Last Post: 11-02-2007, 11:28 PM
  4. CNCAuction.com discussion
    By cncadmin in forum Community Club House
    Last Post: 08-20-2007, 01:46 PM
