586,113 active members*
3,268 visitors online*
Results 1 to 8 of 8
    Apr 2013
    97
    Small mill build X2 spindle
    This is the beginning of a small mill I am building hopefully it will be a little more rigid than the standard X2 kind of a struggle as I don't have access to a milling machine used to where I was working but I'm laid off so I started to put it together the spindle I started about two years ago just put on the back burner made the spacer block mounted the DC treadmill motor at that time here is a couple pictures
    Mar 2013
    124
    Looks awesome mate, keep it going
    Apr 2013
    97
    Quote Originally Posted by Topdecking View Post
    thank you
    Oct 2011
    35
    Looks great!
    I would like to see more progress! I'm trying to making a similar machine, but a little more big!
    Good luck!
    ne(V)esis
    Apr 2013
    97
    Here are a few more pictures got the y-axis stepper mounted and started the electrical
    Apr 2013
    97
    Little more progress here are a couple of pictures
    Apr 2013
    97
    I have added a couple of steel plates to the base here are a few pictures of that and the first test part 6061 aluminum .040 doc. 15 ipm. 2600 RPM part took 11 minutes not counting tool change
    Apr 2013
    97
    Machine is up and running now I don't want to say finished because I don't think they ever are . Got my touch probe's up and working here are a couple pictures. Chips are coming out great with 5/16 end mill .060 doc 20 ipm 3000 RPM aluminum 6061
  1. Looking to build a small table-top CNC mill
    By Particle in forum DIY CNC Router Table Machines
    Last Post: 10-05-2011, 03:55 PM
  2. spindle power vs speed vs torque in a small mill
    By ihavenofish in forum Benchtop Machines
    Last Post: 09-12-2010, 05:14 AM
  3. Considering a (first) machine build, a small desktop mill
    By footloose in forum Open Source CNC Machine Designs
    Last Post: 05-25-2010, 07:12 AM
  4. Replies: 1
    Last Post: 04-17-2006, 06:20 AM
