Hi All
I am hoping some helpful Bridgeport owner can help me here. I have an imperial and metric machine. On the Knee crank there are two dials one that reads in metric 0-2mm and one that reads in imperial (0-100 thou). The imperial dial is driven by an Aluminium disc that is locked in place by a knurled nut. The imperial dial in-turn drives the metric dial with a planetary gear setup so you get 2 readouts. Mine does not appear to be working right. I can disengage it to set the dials to zero but I can't get them to turn with the crank handle.
Explaining what is and is not happening would take too long so I've done a video here:Bridgeport R2E3 BOSS 8.1 imperial and metric knee dials issue - YouTube
Has any one seen this set up?
How is is supposed to work? How are the disc and the imperial ring supposed to mesh? What is the internal knurling on the disc for for or is that a later addition.
Any help is welcome.
Alastair
