Hello from Germany
I will use Madcam to create toolpathes. I have a 10mm high item into a also 10mm high piece of material.
First I take the tool to cut out my item from the rest - that is OK
Now I mark the Item into the material, put the 3mm tool and use the roughing 3D toolpath.
Madcam cannot make a toolpath, it only makes 4 little holes, the other pockets cannot create.
What I must do?
If I delete the 4 holes and start Madcam It makes the pockets...
Sorry, my english is bad. Please use simple english to answer.
Thank you, Ron Attachment 198752
