586,052 active members*
3,972 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Importing a Photovcarve image into Mach3 mill program sizing issue
    Jul 2012
    I am a first time user of Photovcarve. I have an issue with use a prepared Photovcarve image in a Mach3mill program. It seems to cause an oversized run that I have set up. For instance I prepared a 6 x 4 in photo in Photovcarve ( converted to MM ) than exported it in both the mach3 compatable G code Txt file and standard G code file. I than open ether file in Mach3 Mill program, do a test run, and it seems to over size that image by several MM. Mach3 is set up for MM. This happens ether with the Mach3 txt file or the Standard G code file that I have set up. I have looked at the code lines at the start and it does reflect the right size of the image I had setup in the beginning. Any help or suggestions?
    Sounds like your steps per unit settings in Mach3 are off slightly. How much size difference are yuo seeing?
    Jul 2012
    Roughly about a inch and a half. On the steps per unit suggestion. I am not quit clear on setting that up. Any hints?
    It's usually the first thing that you set up in Mach3 after you get the motors moving. You need to make sure the machine moves one inch when you tell it to move one inch.
    There's a built in utility on the Settings page to help you, right above the Reset button.
    Jan 2006
    738
    If you had told Mach3 that your microstepping was 5 when the stepper driver was set on 4, this would give you a 7.5 inch machine movement when commanded 6 inch.
  1. Morbidelli U550 Sizing Issue
    By finbow in forum Commercial CNC Wood Routers
    Last Post: 06-01-2015, 09:43 PM
  2. Importing JPEG image onto a plane as a guide
    By Analias in forum Uncategorised CAD Discussion
    Last Post: 08-25-2013, 08:42 AM
  3. Importing a 2D image
    By rwskinner in forum Benchtop Machines
    Last Post: 02-07-2012, 06:02 PM
  4. Sizing issue
    By ivarton in forum ArtCam Pro
    Last Post: 06-08-2010, 05:05 AM
  5. Importing JPEG Image
    By patrick.jamo in forum CamWorks
    Last Post: 03-26-2009, 05:09 PM
