586,096 active members*
3,444 visitors online*
    Apr 2006
    7
    CNC Engraver needs help?
    Hi Guys,
    New to the forum(and cnc machining/programming) and so far it looks good.
    Do any of you guys have any tips,advice and good tutorial references(in laymans terms)regarding high speed milling machines and software for the purpose of 3d and 2d dies for the printing industry?
    Thank you in advance :cheers:
    Nov 2005
    22
    Looking for the same I have found this:
    http://www.e-engraving.com/
    I also want to make my own machine. Still working on it.
    Good luck !
    Drop a link if you want to look smart....explain if you want to help
    Jan 2006
    11
    try with Artcam software on www.delcam.com it is an exelante software for making a 2d work in a 3d reality allso try with HAAS TM1 or HAAS ofice mill thay should do the job.
    [email protected]
    Feb 2007
    hi there guys,
    i have been using millwrite for years, and it has never let me down, we use a variety of cutters to engrave, ballnose are best we found, we are toolmakers and use highspeed ibag heads.
